TTS™ Metric Tool Holder Set
$1,295.95
31 lbs.
Only 4 left
The TTS™ Metric Tool Holder Set offers everything you need to need to get started and more with our Tormach Tooling System (TTS™) tool holders.
What's In the Box?
In addition to the Tormach Tool Assistant Set and TTS™ Tool Tray, the set includes:
  • Anti-seize grease
  • TTS™ ER Collet Holder: ER20 (six)
  • ER20 collets:
    • 3 mm (two)
    • 6 mm (two)
    • 10 mm (two)
  • ER20 Deluxe TTS Wrench Set
  • TTS™ set screw holders:
    • 10 mm (two)
    • 12 mm (two)
  • Jacobs Drill Chuck-1/4-inch-JT1
  • Jacobs Drill Chuck-3/8-inch-JT2 (two)
  • TTS™ Drill Chuck Arbor: JT1 taper
  • TTS™ Drill Chuck Arbor: JT2 taper (two)
The TTS™ Metric Tool Holder Set provides everything you need to get started with our Tormach Tooling System (TTS™) and expanded tool holding options, and includes the Tormach Tool Assistant Set and TTS™ Tool Tray.
Features:
  • Tool holders:
    • ER20 collet holders
    • Set screw holders
    • Jacobs chucks for drills
  • Tormach Tool Assistant Set:
    • Compact, granite surface plate
    • Integrated clearance hole
    • 200 mm digital height gauge
    • USB interface cable with touch trigger for PathPilot integration
  • TTS™ Tool Tray:
    • Varnished wood
    • Storage for 21 TTS™ tools
  • 1100M
  • 770M
  • PCNC 1100
  • PCNC 770
  • PCNC 440
