Passive Probe Kit
$395.00
2 lbs.
The Passive Probe Kit is an economical probe that quickly and automatically sets work offsets using PathPilot’s integrated probing routines.
What's In the Box?
In addition to the probe, the kit includes:
  • Cardboard box with fitted foam lining
  • Stainless steel probe tip
  • Factory inspection and certification report
  • Installation and maintenance instructions
  • Installation wrenches:
    • 2 mm hex
    • 2 mm pin
    • 2.5 mm hex
  • TTS Gauge Holder: 10 mm
Quickly and automatically set work offsets using PathPilot’s integrated probing routines. Compatible with the Renishaw M4 stylus family, this economical kit features:
  • 3D touch trigger probe
  • Indicator light when triggered
  • Plug-and-play integration with Tormach mills
  • 1100M
  • 770M
  • PCNC 1100
  • PCNC 770
  • PCNC 440
Requirements
  • PathPilot controller
  • Regular cleaning of probe contacts (we recommend every three to six months, depending on your work environment)
Specifications
2σ Repeatability ≤ 0.015 mm
Measuring direction ±X, ±Y, & +Z
Maximum Over-Travel In +Z + 5.0 mm
Maximum Angular Displacement ± 15°
Radial (X-Y)trigger force 30-60 g
Axial(Z)trigger force 500±30 g
Water Resistance IP66
Support
Learn More
