Lifting Bar Kit
$205.00
17 lbs.
The Lifting Bar Kit provides safe and balanced lifting of our milling machines
What's In the Box?
- Chain
- Clevises
- Lifting eye
- T-slot anchors
For maximum safety and security, always lift our milling machines using an overhead method. The Lifting Bar Kit is designed for safe and balanced lifting with a hoist or other overhead method, and features:
- 3/8 in. (9.5 mm) thick steel lifting bar
- G80-rated, high-strength chain
- High-strength shackles rated for a minimum weight of 1 T (900 kg)
- 1100mx
- 770mx
- 1100M
- 770M
- PCNC 1100
- PCNC 770
Requirements
- 2 T (1800 kg) engine hoist or similar lifting apparatus
