Freestanding light curtain safety device with corner mirrors
$1,399.00
58 lbs.
Only 1 left
Designed to plug directly into the ZA6 robot’s safety input, this light curtain set allows you to safely isolate up to 95 square feet (9 m^2) of area for industrial robot applications.
Designed to plug directly into the ZA6 robot’s safety input, this light curtain set allows you to safely isolate up to 95 square feet (9 m^2) of area for industrial robot applications. The set includes a full-length (1m) emitter, receiver, and two corner mirrors all encased in rugged, safety-yellow aluminum extruded housings that are designed to be anchored to the floor in a permanent safety installation. Floor mounting plates and concrete anchors are included.
Specifications
Max distance from emitter to receiver: 30ft (9m)
15ms response time
Effectively shields over 99% of external light interference (anti-light interference 10000lux @ incidence angle≥5°)
Power: 24VDC @<200mA, supplied by the ZA6 robot electrical cabinet
Waterproof rating: IP65
Working temperature range: -10~+40℃
Optical beam spacing: 40mm
