Light Curtain Safety Device - Short
$355.00
3 lbs.
The ZA6 robot requires the presence of a safety input to function. The 51173 light curtain sender/receiver pair comes with mounting hardware and is pre-wired with an M12 connector for use with the ZA6’s safety input.
  • Dimension: 1.43 in. x 1.18 in. x 13.23 in. (36.5 mm x 30 mm x 33 mm
  • Working distance between transmitter and receiver: .79 in. - 118.11 in. (20 mm - 3000 mm.)
  • Detection resolution (minimum detected size): .98 in. (25 mm)
  • Response time: 10ms – 65ms
  • Enclosure rating: IP65
Specifications:
  • Effective Aperture Angle: Less than 5 degree at 3.28 ft. (3 m)
  • Electrical specification
  • Environmental resistance:
    • Ambient light: Incandescent lamp: 3,000 lux max., fluorescent lamp : 3,00 lux max., Sunlight: 10,000 lux max.
  • Operating ambient temperature: -4° - 140° F (-20℃-60℃)
  • Operating relative humidity: 35% to 85% RH
  • Pre-wired for use with ZA6 Robot
What’s in the box:
  • Sender/receiver pair
  • Mounting brackets
  • Mounting T studs
  • 10m cable with M12 connector
