M12 connector splitter
$29.95
0.3 lbs.
Only 5 left
Each digital input and output connector on the ZA6 has two channels of input or output. This M12 male connector wired to two M12 female connectors allows you to use both channels.
- Cable length : 11.8 in. (300mm)
- Rated current: 4A
- Rated voltage: 125V
- waterproof: IP67
Specifications:
- Prevent wrong insertion code: A-Coded
- Cable gauge: 5*22AWG
- Rated impulse voltage: 1500
- Rated current: 4A
- Contact resistance: ≤3mΩ
- Lock: M12
- waterproof: IP67
- Working temperature: -40 - 185 F (-40 - 85C)
- Wiring:
- CN1: 1,2,3,4,5
- CN2: 1,2,3,4,5
- CN3: 1,4,3,2,5
