Machine Arm
The Machine Arm can be mounted directly on to either side of the machine and has rigid support with a machined cast iron support bracket, two sturdy steel extension arms and a center pivot
The machine arm can be mounted directly to either side of the machine column. It features a rigid machined cast iron support bracket with two sturdy steel extension arms and a center pivoting hinge. It is fully adjustable and easy to install. Any LCD with a standard VESA 75 mm or 100 mm mount can be attached with the included hardware kit.
Every PCNC machine comes with the column drilled and tapped to fit our cast iron bracket. The supporting arms are machined to allow for routing of the cables inside the arms. Please note, LCD displays and keyboards will require appropriate extension cables when used with the Machine Arm.
Learn More
