microARC 6 Subplate
MicroArc 6 SubPlate
11.25 in. x 9.95 in. x 0.95 in. 6061 Aluminum Mounting Plate for Tormach microARC 6 4th axis rotaries. The plate is reversible for +X or -X mounting location. This plate is designed to mount directly to an SMW fixture plate OR the Tormach 1500MX table.
Includes hardware for mounting the microARC 6 to the subplate and for mounting the subplate to an SMW fixture plate or machine table (t-nuts are included, but only necessary for mounting to machine table). This subplate has an alignment feature for using the 16mm key on the underside of the microARC, however we recommend removing the key and tramming the rotary when it is installed on the subplate for best results.
Tormach microARC can remain mounted to the subplate when removed from the machine for simpler setup. Subplate is designed to be aligned using (2) user-provided dowel pins OR SMW Fixturing Pins in the SMW fixture plate for easy alignment and repeatability.
