MT-3 Live Center
$33.95
2.75 lbs.
The MT-3 Taper Live Center is for use with medium duty lathe work
MT-3 Taper Live Center for medium duty lathe work. Can also be used for 4th Axis.
- Ground Steel Construction
- Maximum Speed Rating: 4000 RPM
- Maximum Radial Load Rating: 450 lbs.
- Overall Length: 7"
- Stock Length: 3.8"
- Point Angle: 60°
- Diameter at base of Point: 0.95"
