MT-1 Live Center
$29.95
0.75 lbs.
The MT-1 Taper Live Center is for Light Duty Lathe Work
MT-1 Taper Live Center for light duty lathe work. Can also be used for 4th Axis.
- Ground Steel Construction
- Maximum Speed Rating: 5000 RPM
- Maximum Radial Load Rating: 70 lbs.
- Overall Length: 4.6"
- Stock Length: 2.4"
- Point Angle: 60°
- Diameter at base of Point: 0.7"
