As we begin 2021, we have found ourselves in a situation where our lead-times have substantially increased due to COVID-19 pandemic-related issues.
Those issues combined with high demand and heavy shipping volume is resulting in a longer than normal delivery timeframes for many Tormach machines and accessories.
We are working diligently to resolve these issues and look forward to bringing our lead-times back to normal. Unfortunately, this is going to take some time.
As of now, we anticipate that these lead times will continue into the second quarter. We appreciate your patience during this time.
NUMBERED PARAMETERS REFERENCE
The # character may be repeated; for example ##2 means the value of parameter whose index is the (integer) value of parameter 2. PathPilot maintains a number of read-only parameters. Only parameters for the relevant axes are maintained: (X Y Z A) for mill and (X Z) for mill. The remaining parameters for unused axes are undefined.
READ-ONLY PARAMETERS
  • 5220: Current coordinate system number 1-9 for G54 – G59.3
  • 5400: Current tool number
  • 5410: Current tool diameter
  • 5413: Current tool orientation
