Oil Skimmer Kit for 1100M/1100MX, 770M/770MX, and PCNC 440
The Oil Skimmer Kit for 1100M / 1100MX,770M / 770MX, and PCNC 440 extends coolant life by removing tramp oil from the coolant tank
The Oil Skimmer Kit for 1100M / 1100MX, 770M / 770MX, and PCNC 440 extends coolant life by removing tramp oil from the coolant tank. Once removed, the tramp oil is collected in a container for easy disposal. Removing floating surface oils also extends cutting tool life and creates a cleaner shop environment reducing the potential for smoke and odors. Features include:
- 3/4 in. (19 mm) Kevlar-reinforced, toothed belt made of polyurethane for durability and chemical resistance
- Low power consumption for minimal electricity costs
Some assembly required.
- 1100M / 1100MX
- 770M / 770MX
- PCNC 440
- This product will not work on 50Hz electrical grids, 60Hz is required.
Specifications
Container Storage Capacity | 38.5 oz (1.1 L) |
Voltage | 115 Vac |
What's In the Box?
In addition to the oil skimmer, items include:
- Installation instructions
- Mounting hardware
- Tramp oil collection container
Note: Only for use in US and Canada.
