Optical Grinding Wheel Dresser
Optical Universal Wheel Dresser for surface grinder; can be used to dress straight line bevels, concave arcs, or convex arcs
Optical Wheel Dresser for surface grinder. Can be used dress straight line bevels, concave arcs, convex arcs, or combination profiles. Compatible with 1/4 in. or 12 mm Radius Diamond Pins.
- Ground steel construction with knurled adjustment knobs
- Height to Center: 65 mm (2.56 in.)
- Max. Wheel Diameter: 205 mm (8 in.)
- Max. Convex Arc: 13 mm (0.5 in.)
- Max. Concave Arc: 25.4 mm (1 in.)
- Angular Swing: 95° to -95°
- Max Sliding Block Displacement: 22.5 mm (0.85 in.)
- Use with either 1/4 in. or 12 mm diameter Radius Diamonds
- Overall Dimensions: 230 mm x 75 mm x 97 mm (9 in. x 3 in. x 3.8 in.)
- Includes wooden storage crate
Learn More
