PARAMETERS REFERENCE
PARAMETER SYNTAX
  • Numbered – #4711
  • Named local – #
  • Named global – #<_globalvalue>
PARAMETER SCOPE
BEHAVIOR OF UNINITIALIZED PARAMETERS
PARAMETER MODE
PERSISTENCE AND VOLATILITY
INTENDED USAGE
