Passive Probe Kit (BT30)
$519.00
2 lbs.
Quickly and automatically set work offsets using PathPilot’s integrated probing routines. Compatible with the Renishaw M4 stylus family, this economical kit features:
  • 3D touch trigger probe
  • Indicator light when triggered
  • Plug-and-play integration with Tormach mills
  • 1100MX
  • 770MX
Requirements
  • PathPilot controller
Specifications
Measuring Direction ±X, ±Y, & +Z
Repeatability 0.00059 in. (0.015 mm)
Maximum Over-Travel In +Z + .1968 in. (5.0 mm)
Maximum Angular Displacement ± 15°
Radial (X-Y) Trigger Force 30-60 g
Axial Trigger Force 500 ± 30 g
Water Resistance IP66
What's In the Box?
In addition to the probe, the kit includes:
  • BT30 Tool Holder, Probe, 10mm
  • Stainless steel tip
  • Installation wrenches:
    • 2 mm hex
    • 2 mm pin
    • 2.5 mm hex
