PCNC 440 Advanced EDU Bundle
PCNC 440 Mill This product is required for the machine. $6,495.00
PCNC 440 Stand This product is required for the machine. $995.00
PCNC 440 Chip Pan This product is required for the machine. $695.00
PCNC 440 Enclosure Kit This product is required for the machine. $1,795.00
PCNC 440 Enclosure Door Switch Kit This product is required for the machine. $99.95
PCNC 440 Printed Manual $19.95
PathPilot Controller for PCNC Mills and 15L Lathe This product is required for the machine. $495.00
Controller Arm This product is required for the machine. $359.95
Touch Screen Kit This product is required for the machine. $459.95
Jog Shuttle Controller This product is required for the machine. $99.95
Flood Coolant Kit for PCNC 440 This product is required for the machine. $499.95
Portable Refractometer - Coolant Tester $19.95
PCNC 440 Power Drawbar Kit This product is required for the machine. $995.00
8-Pocket Automatic Tool Changer for PCNC 440 This product is required for the machine. $3,570.00
4 in. CNC Vise $395.00
Clamp Kit for 3/8 in. T-Slots (58 Pcs.) $69.95
Compact TTS™ Tool Tightening Fixture $45.95
TTS™ CNC Operator Set with Tormach Tool Assistant $1,195.95
End Mill Kit for Aluminum #1 $499.95
TTS™ Diamond Drag Engraver Kit $99.95
TTS™ MiniShear .750 in. $289.95
4 in. Parallel Set $49.95
XDET 2.522 (Mini-Shear) Insert 10-Pack $224.95
1-2-3 Block Set $24.95
Professional Metalworking Gauge Kit $379.95
Passive Probe Kit $429.95
Probe Stylus, 50mm Length, 6mm Ruby Ball, M4 Thread $149.95
PCNC 440 Extended Warranty $695.00
More Info Stock: In Stock
Partial Machine Assembly (Optional) $1,195.00
* Required Fields
X-Axis: 10 in. (254 mm)
Y-Axis: 6.25 in. (158.75 mm)
Z-Axis: 10 in. (254 mm)
Maximum Speed: 10.000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Tapping: Thread Mill
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
Assembly
