PCNC 440 Basic EDU Bundle
PCNC 440 Mill This product is required for the machine. $7,450.00
PCNC 440 Stand This product is required for the machine. $1,119.00
PCNC 440 Chip Pan This product is required for the machine. $745.00
PCNC 440 Enclosure Kit This product is required for the machine. $2,029.00
PCNC 440 Enclosure Door Switch Kit This product is required for the machine. $113.00
PCNC 440 Printed Manual $22.95
PathPilot Controller for PCNC Mills and 15L Lathe This product is required for the machine. $1,015.00
Jog Shuttle Controller This product is required for the machine. $113.00
Standard LCD Monitor This product is required for the machine. $319.00
Controller Arm This product is required for the machine. $409.00
4 in. CNC Vise $445.00
Clamp Kit for 3/8 in. T-Slots (58 Pcs.) $79.95
Compact TTS™ Tool Tightening Fixture $52.95
Cutting Tool Starter Set #1 $359.00
Manual Operator Set (Inch) $286.00
1/2 in. Shank Edge Finder $16.95
Basic 3 Piece Indicator Set $150.00
PCNC 440 Extended Warranty $695.00
More Info In Stock
Partial Machine Assembly (Optional) $1,195.00
More Info In Stock
* Required Fields
X-Axis: 10 in. (254 mm)
Y-Axis: 6.25 in. (158.75 mm)
Z-Axis: 10 in. (254 mm)
Maximum Speed: 10.000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Tapping: Thread Mill
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
PATHPILOT® Controller
Assembly
PCNC 440 Assembly is available for $1,195 .
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
