PCNC 440 Basic EDU Bundle
PCNC 440 Mill This product is required for the machine. $6,495.00
PCNC 440 Stand This product is required for the machine. $995.00
PCNC 440 Chip Pan This product is required for the machine. $695.00
PCNC 440 Enclosure Kit This product is required for the machine. $1,795.00
PCNC 440 Enclosure Door Switch Kit This product is required for the machine. $99.95
PCNC 440 Printed Manual $19.95
PathPilot Controller for PCNC Mills and 15L Lathe This product is required for the machine. $495.00
Jog Shuttle Controller This product is required for the machine. $99.95
Standard LCD Monitor This product is required for the machine. $279.95
Controller Arm This product is required for the machine. $359.95
4 in. CNC Vise $395.00
Clamp Kit for 3/8 in. T-Slots (58 Pcs.) $69.95
Compact TTS™ Tool Tightening Fixture $45.95
Cutting Tool Starter Set #1 $249.95
Manual Operator Set (Inch) $249.95
1/2 in. Shank Edge Finder $14.95
PCNC 440 Extended Warranty $695.00
More Info Stock: In Stock
Partial Machine Assembly (Optional) $1,195.00
* Required Fields
X-Axis: 10 in. (254 mm)
Y-Axis: 6.25 in. (158.75 mm)
Z-Axis: 10 in. (254 mm)
Maximum Speed: 10.000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Tapping: Thread Mill
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
Assembly
