PCNC 440 Intermediate EDU Bundle
PCNC 440 Mill This product is required for the machine. $7,450.00
PCNC 440 Stand This product is required for the machine. $1,119.00
PCNC 440 Chip Pan This product is required for the machine. $745.00
PCNC 440 Enclosure Kit This product is required for the machine. $2,029.00
PCNC 440 Enclosure Door Switch Kit This product is required for the machine. $113.00
PCNC 440 Printed Manual $22.95
PathPilot Controller for PCNC Mills and 15L Lathe This product is required for the machine. $1,015.00
Controller Arm This product is required for the machine. $409.00
Standard LCD Monitor This product is required for the machine. $319.00
Jog Shuttle Controller This product is required for the machine. $113.00
Flood Coolant Kit for PCNC 440 This product is required for the machine. $565.00
QualiChem XTREME CUT 251C This product is required for the machine. $67.95
PCNC 440 Power Drawbar Kit This product is required for the machine. $1,119.00
4 in. CNC Vise $445.00
Clamp Kit for 3/8 in. T-Slots (58 Pcs.) $79.95
ER20 Collet Set (15 Pcs.) - Inch $113.00
1/16 in. - 1/2 in. Machine Length Drill Set $211.00
Compact TTS™ Tool Tightening Fixture $52.95
TTS™ CNC Operator Set with Tormach Tool Assistant $1,345.00
End Mill Kit for Aluminum #1 $535.00
HAIMER 3D-Sensor New Generation Kit (Metric) $655.00
Metric Ball Replacement Tip for Haimer Zero Master/ 3D Sensor $59.95
PathPilot Software Bootable USB Drive - Recovery Media $28.95
PCNC 440 Extended Warranty $695.00
More Info In Stock
Partial Machine Assembly (Optional) $1,195.00
More Info In Stock
* Required Fields
X-Axis: 10 in. (254 mm)
Y-Axis: 6.25 in. (158.75 mm)
Z-Axis: 10 in. (254 mm)
Maximum Speed: 10.000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Tapping: Thread Mill
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
PATHPILOT® Controller
Assembly
PCNC 440 Assembly is available for $1,195 .
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
