PCNC 440 Starter Package
PCNC 440 Mill This product is required for the machine. $7,995.00
Lyndex TTS™ Adapter Collet: R8 This product is required for the machine. Lyndex TTS™ Adapter Collet: R8
PCNC 440 Stand $1,165.00
PCNC 440 Enclosure Kit $2,115.00
PCNC 440 Chip Pan $779.00
PCNC 440 Enclosure Door Switch Kit $118.00
Recommended items:
PCNC 440 Printed Manual $23.95
Related items:
Anti-Fatigue Tormach Logo Mat $58.95
PathPilot Keyboard Shortcuts Mousepad $16.95
36 in. x 24 in. Satin Tormach Banner with Top Grommets $27.95
PathPilot Controller for PCNC Mills and 15L Lathe This product is required for the machine. $975.00
Standard LCD Monitor $335.00
Touch Screen Kit $545.00
$48.95
Waterproof Mini-Keyboard $48.95
$28.95
Waterproof Mouse $28.95
Jog Shuttle Controller $118.00
Controller Arm $429.00
USB M-Code I/O Interface Kit $309.00
Recommended items:
Passive Probe Kit $509.00
Probe Stylus, 50mm Length, 6mm Ruby Ball, M4 Thread $118.00
Recommended items:
HAIMER 3D-Sensor New Generation Kit (Metric) $655.00
Metric Ball Replacement Tip for Haimer Zero Master/ 3D Sensor $61.95
Recommended items:
1/2 in. Shank Edge Finder $17.95
3/8 in. Shank Edge Finder $16.95
Laser Edge/Center Finder (Bullseye) $213.00
Laser Edge/Center Finder (Center Spot) $213.00
TTS™ Touch Tool w/Mechanical Indicator and Box $58.95
TTS™ Touch Tool w/Digital Indicator and Box $94.95
Flood Coolant Kit for PCNC 440 $589.00
Portable Refractometer - Coolant Tester $23.95
1/4 in. Coolant Hose, 6 in. Segment (2 PC) $15.95
1/4 in. Coolant Hose Accessory Kit w/Pliers $58.95
SmartCool Starter Kit $825.00
Recommended items:
FogBuster Coolant Kit (115 Vac) for PCNC Mills $685.00
Pneumatic Hose Kit for Power Drawbar/ATC/Fogbuster $41.95
Recommended items:
8-Pocket Automatic Tool Changer for PCNC 440 $3,995.00
PCNC 440 Power Drawbar Kit $1,165.00
California Air Tools 4610XC Air Compressor $399.00
microARC 4 - 100 mm 4th Axis $3,591.00
PCNC 440 Driver & Wiring Kit for 100mm 4th Axis PCNC 440 Driver & Wiring Kit for 100mm 4th Axis
ER40 Collet Set (8 Pcs.) - Inch $100.95
ER40 Collet Set (8 Pcs.) - Metric $100.95
Recommended items:
4 in. CNC Vise $445.00
6 in. TalonGrip™ Vise Jaw Systems  - Mitee-Bite - Compatible with Tormach 4 in. and 5 in. vises $201.00
VersaGrip™ Vise Jaws - Mitee-Bite - Compatible with Tormach 4 in. and 5 in. vises $232.00
4 in. Parallel Set $58.95
Adjustable Parallel Set $51.95
Wavy Parallel Set $58.95
Work Stop $58.95
Recommended items:
Clamp Kit for 3/8 in. T-Slots (58 Pcs.) $82.95
T-Slot Bridge Nut for PCNC 440 $27.95
3/8 in. T-Slot Nut $7.95
Recommended items:
SMW Fixture Tooling Plate for PCNC 440
Includes fixture tooling plate (PN 38208) bundled with mounting hardware and the most popular fixturing accessories (PN 52309).
440 Fixture Tooling Plate Accessory Kit $519.00
Fixture Tooling Plate Accessory Upgrade Kit $635.00
Related items:
3 Jaw Chuck for 6 in. (152 mm) Table $465.00
5C Collet Block Set $107.00
5C Round Collet Set (18 Pcs.) - Inch $179.00
5C Hex Collet Set (13 Pcs.) - Inch $159.95
5C Emergency Brass Collet $35.95
5C Adjustable Collet Stop $15.95
Huot 5C Collet Rack $47.95
Recommended items:
Cutting Tool Starter Set #2 $945.00
YG-1 V7 Plus A Series Steel, Cast Iron & Stainless End Mill Kit $705.00
Cutting Tool Starter Set #1 $375.00
Thread Mill Kit
More Info In Stock
#8 x 1/2 in. x 1/4 in. Thread Mill $35.95
#10 x 1/2 in. x 1/4 in. Thread Mill $38.95
#12 x 5/8 in. x 1/4 in.  Thread Mill $42.95
1/4 x 3/4 in. x 3/16 in. Thread Mill $46.95
5/16 x 3/4 in. x 5/16 in. Thread Mill $58.95
3/8 in. x 1 in. x 3/8 in. Thread Mill $70.95
1/2 in. x 1-1/4 in. x 1/2 in. Thread Mill $94.95
TTS™ CNC Operator Set with Tormach Tool Assistant $1,399.00
Manual Operator Set (Inch) $297.00
TTS™ Metric Tool Holder Set $1,525.00
Compact TTS™ Tool Tightening Fixture $54.95
TTS™ Set Screw Holder: 1/4 in. $35.95
TTS™ Set Screw Holder: 5/16 in. $29.95
TTS™ Set Screw Holder: 1/2 in. $36.95
TTS™ Set Screw Holder: 6mm $36.95
TTS™ Set Screw Holder: 10mm $36.95
TTS™ Set Screw Holder: 12mm $36.95
TTS™ Set Screw Holder: 3/8 in. $36.95
TTS™ Machinable Blank $35.95
TTS™ Saw Arbor: 1/2 in. $82.95
TTS™ Saw Arbor: 1 in. $82.95
TTS™ ER Collet Holder: ER20 $50.95
TTS™ ER Collet Holder: ER16 $43.95
TTS™ ER Collet Holder: ER32 $52.95
ER20 Collet Set (15 Pcs.) - Inch $118.00
ER16 Collet Set (22 Pcs.) - Inch $235.00
ER32 Collet Set (12 Pcs.) - Inch $219.00
TTS™ SuperFly Cutter Kit $189.00
Carbide Insert for Steel - Face Mill/Fly Cutter 10-Pack $96.95
Carbide Insert for Aluminum and Plastic - Face Mill/Fly Cutter 10-Pack $110.00
Recommended items:
TTS™ Mini-Shear .750 in. $345.00
XDET 2.522 (Mini-Shear) Insert 10-Pack $268.00
XDET 2.52-010 (Mini-Shear) Insert 10-Pack $297.00
Recommended items:
Mini-Shear - .500 in. $280.00
Recommended items:
Mini-Shear - .500 in. MIT Cutting Head $275.00
TTS™ M6 Threaded Arbor: Short $46.95
Recommended items:
TTS™ Diamond Drag Engraver Kit $118.00
Spring-Loaded CNC Drag Knife $201.00
Dial Test Indicator Kit $190.00
1-2-3 Block Set $29.95
More Info In Stock
More Info In Stock
Free SprutCAM 3 Month Trial
More Info In Stock
PCNC 440 Extended Warranty $695.00
More Info In Stock
Partial Machine Assembly (Optional) $1,195.00
More Info In Stock
On-site Service Quote Request
On-site machine installation and training is available for an additional charge ($2,000 reservation fee + $2,000 per day of service) when purchasing a new machine. Check the box to quote this service.
* Required Fields
X-Axis: 10 in. (254 mm)
Y-Axis: 6.25 in. (158.75 mm)
Z-Axis: 10 in. (254 mm)
Maximum Speed: 10.000 RPM
Transmission: Poly-V belt
Spindle Taper: R8
Tapping: Thread Mill
Maximum Feed Rate
Z-Axis: 110 IPM (2.79 m/min)
PATHPILOT® Controller
Assembly
PCNC 440 Assembly is available for $1,195 .
Spindle Taper: R8
Maximum Feed Rate
80GB program memory
Assembly
