PECK DRILLING CYCLE (G83)
- Q~ is a delta increment along the Z-axis
The G83 cycle is as follows:
- Step 1: Preliminary canned cycle motion.
- Step 2: Move the Z-axis only at the current feed rate downward by delta or to the Z position, whichever is less deep.
- Step 3: Rapid back out to the clear Z.
- Step 4: Repeat Steps 1 through 3 until the Z position is reached at Step 1.
- Step 5: Rapid back down to the current hole bottom, backed off a bit.
- Step 6: Retract the Z-axis at traverse rate to clear Z.
TROUBLESHOOTING
It’s an error if:
- The Q number is negative or zero
