Power Drawbar Kit for 1100M / 770M
The Power Drawbar Kit supplies a pneumatic power drawbar that increases productivity and efficiency through push-button tool changes.
What's In the Box?
- 1/4 in. industrial-shape, quick-connect coupling
- Cylinder assembly
- Filter-regulator-lubricator (FRL) unit
- Pneumatic lines
- Valve assembly
Manually changing your Tormach Tooling System (TTS) tools takes time and effort, which reduces productivity. Instead, use the pneumatic power drawbar for lightning-fast, push-button tool changes to keep you making chips, not spinning wrenches.
Features:
- Floating pneumatic cylinder unclamps tools without stressing spindle bearings
- Included filter-regulator-lubricator (FRL) unit cleans and conditions shop air for extended seal life
- Easy installation kit has the drawbar up and running in minutes
Some assembly required.
- 1100M
- 770M
- Tormach Tooling System (TTS) tools
Requirements
- 90 psi to 120 psi (620 kPa to 840 kPa) compressed air source
Learn More
