Powermax105 SYNC Hypertherm plasma cutter
Powermax105 SYNC plasma cutter
- Recommended for cutting up to 1 1/4in. @ 20IPM
- Severance (hand cutting) thickness: 2in.
- Pierce*: 7/8
- 50:1 Voltage Divider
- CPC Machine Control Port
- Serial Port
- 200-600V 1/3-PH, CSA
*Pierce rating for handheld use or with automatic torch height control.
Note: I/O cables not included (CPC control cable is included with the 1300PL)
The Powermax105 SYNC™ is a next-generation, professional-grade air plasma cutter that dramatically simplifies system operation for cutting and gouging up to 32 mm (1-1/4 in.). Features automated system process set-up via advanced RFID-enabled SmartSYNC™ torches, and a revolutionary single-piece cartridge consumable that provides trackable utilization data. The Powermax105 SYNC maximizes productivity through reductions in downtime, optimized cut quality performance, and streamlined consumable inventory management.
Maximum Productivity
- Finish jobs faster with cut speeds one and a half times greater than oxyfuel on 1/2 in. (12mm) mild steel
- Superior cut and gouge quality let you spend less time on grinding and edge preparation
- Multiple, easy-to-use torch styles let you tackle a wide variety of jobs using the same system
Easy-to-Use
- No need to change the air pressure - Smart Sense™ technology ensures that it is always correctly set
- SpringStart™ technology ensures consistent starting and a more reliable torch
- Drag cut at full output with a patented shield that reduces dross buildup for smoother cutting
Rugged and Reliable
- Hypertherm Certified™ reliability ensures peak performance even in the harshest environments
- Duramax torches are designed for high-impact and heat resistance
Low Operating Costs
- Reduce costs with long consumable life and more uptime
- High power efficiency lowers energy consumption
Built and Tested to Withstand Harsh Conditions
- Duramax® torches are designed for high-impact and heat resistance
- Low maintenance for maximum uptime
Includes: 180deg; machine torch, 25 ft leads, starter consumable kit
Hypertherm Part Number: 059684
Specifications
Capacity: Recommended | Thickness: 32 mm ( 1-1/4 in.) | Cut Speed: 500 mm/min (20 ipm) |
Thickness: 38 mm ( 1-1/2 in.) | Cut Speed: 250 mm/min (10 ipm) | |
Capacity: Severance (Hand Cutting) | Thickness: 50 mm (2 in.) | Cut Speed: 125 mm/min (5 ipm) |
Capacity: Pierce* | Thickness: 22mm (7/8 in.) |
*Pierce rating for handheld cutting, or mechanized cutting with programmable torch height control
Air Requirements:
Clean, dry, oil-free air or nitrogen
6.7 cfm @ 90 psi. For high duty cycle use, a compressor capable of 1.5x - 2x this amount is recommended.
