Powermax45 Sync Hypertherm Plasma Cutter
- Includes 25 foot machine torch.
- 230V CSA model with CPC port, voltage divider board, and serial port.
- Recommended for cutting up to 5/8 in. (@ 20 IPM)
- Severance (hand cutting) thickness: 1 1/8 in.
- Pierce*: 1/2 in.
*Pierce rating for handheld use or with automatic torch height control.
Note: This item typically has a two week lead time.
For metal workers who want the most versatile system available to gouge, cut, and mark, Powermax45 SYNC delivers the best return on investment with a patented single-piece cartridge, up to 5x longer consumable life, and greater cutting power than higher-amperage competitors.
Simplify operations and boost productivity
- Simplified system operation minimizes the time and costs spent on training and troubleshooting.
- Reductions to downtime during consumable change-outs and elimination of costs associated with premature disposal of consumable parts.
- Cartridge usage data provides valuable insights for improving cutting operations and consumable inventory management.
Easy-to-Use
- Cartridges are easy to identify by process with clear laser marking and color coding to eliminate part mix-ups.
- RFID-enabled SmartSYNC torches and cartridges automatically set the correct amperage and operating mode, eliminating setup errors.
- End-of-life consumable detection eliminates the uncertainty of knowing when to change the cartridge.
- Less operator fatigue when using hand torches with our new flexible lead. The lead has the same robustness of our previous lead jacket material and will also be used on robotic torches.
- Cartridge reader and RFID
Maximize performance
- Tackle a wide range of jobs with easily interchangeable torch styles and application specific cartridges for various types of cutting and gouging.
- Optimized cartridge consumable design provides up to twice the life for handheld cutting and improved quality over life in mechanized setups compared to standard consumables.
- Time-saving hand torch controls allow the operator to adjust the amperage on the fly, change cartridges and applications without returning to the power supply.
- Powermax SYNC mechanized cut samples
Industry-leading reliability
- SmartSYNC torches are engineered for rugged, industrial environments.
- SpringStart™ technology ensures consistent starting and a more reliable torch.
- Industry-leading reliability reduces production downtime.
Includes: 180deg; machine torch, 25 ft leads, starter consumable kit
Specifications
Capacity: Recommended | Thickness: 16 mm (5/8 in.) | Cut Speed: 500 mm/min (20 ipm) |
Capacity: Severance (Hand Cutting) | Thickness: 29 mm (1-1/8 in.) | Cut Speed: 125 mm/min (5 ipm) |
Capacity: Pierce* | Thickness: 12 mm (1/2 in.) | |
Capacity: Typical Gouge | Metal Removal Rate (Gouging): 3.4 kg (7.5 lbs) per hour | Groove Profile: 3.2 mm (.12 in.) D x 6.8 mm (.26 in.) W |
Air Requirements:
Clean, dry, oil-free air, nitrogen, F5
Recommended gas inlet flow rate/pressure: 188 I/min @ 5.9 bar (400 scfh @ 85 psi)
