Powermax65 SYNC Hypertherm plasma cutter
$4,375.00
65 lbs.
Only 5 left
Powermax65 SYNC plasma cutter
Recommended for cutting up to 1 in. (@ 10 IPM)
Severance (hand cutting) thickness: 1 1/4 in.
Pierce*: 5/8 in.
*Pierce rating for handheld use or with automatic torch height control.
The Powermax65 SYNC™ is a next-generation professional-grade air plasma cutter that dramatically simplifies system operation for cutting and gouging up to 20 mm (3/4″). Featuring an automated system process set-up via advanced RFID-enabled SmartSYNC™ torches and a revolutionary single-piece cartridge consumable that provides trackable utilization data. The Powermax65 SYNC maximizes productivity through reductions in downtime, optimized cut quality performance, and streamlined consumable inventory management.
Specifications
Capacity: Recommended Thickness: 20 mm ( 3/4 in.) Cut Speed: 500 mm/min (20 ipm)
Thickness: 25 mm ( 1 in.) Cut Speed: 250 mm/min (10 ipm)
Capacity: Severance (Hand Cutting) Thickness: 32 mm (1-1/4 in.) Cut Speed: 125 mm/min (5 ipm)
Capacity: Pierce* Thickness: 16mm (5/8 in.)
*Pierce rating for handheld cutting, or mechanized cutting with programmable torch height control
Air Requirements:
Clean, dry, oil-free air or nitrogen
6.7 cfm @ 90 psi. For high duty cycle use, a compressor capable of 1.5x - 2x this amount is recommended.
