Due to high demand and worldwide supply chain issues, we are experiencing longer than normal delivery time frames for many Tormach machines and accessories. We appreciate your patience during this time.
Note: The ONLY way to secure a machine that is currently on backorder is to place an order for one. You may place a deposit to hold your spot in line for machines arriving. Without an order, any dates presented on our website are subject to change with demand.
Powermax85 Hypertherm Plasma Cutter
$4,275.00
75 lbs.
Only 3 left
Hypertherm Powermax85 Torch CSA model
  • 50:1 Voltage Divider
  • CPC Machine Control Port
  • Serial Port
  • 200-600V 1/3-PH, CSA
Note: I/O cables not included (CPC control cable is included with the 1300PL)
The premier system for cutting 25 mm (1"), the Powermax85® has the same features and options as the Powermax65®, but with more power from an output current of 85 amps. Designed to maximize uptime and productivity, the system offers the latest technological innovations, such as Smart Sense™ technology to automatically adjust the gas pressure.
Maximum Productivity
  • Finish jobs faster with cut speeds one and a half times greater than oxyfuel on 1/2 in. (12 mm) mild steel
  • Superior cut and gouge quality let you spend less time on grinding and edge preparation
  • Multiple, easy-to-use torch styles let you tackle a wide variety of jobs using the same system
Easy-to-Use
  • No need to change the air pressure – Smart Sense™ technology ensures that it is always correctly set
  • SpringStart™ technology ensures consistent starting and a more reliable torch
  • Drag cut at full output with a patented shield that reduces dross buildup for smoother cutting
Rugged and Reliable
  • Hypertherm Certified™ reliability ensures peak performance even in the harshest environments
  • Duramax torches are designed for high-impact and heat resistance.
Low Operating Costs
  • Reduce costs with long consumable life and more uptime
  • High power efficiency lowers energy consumption
Built and Tested to Withstand Harsh Conditions
  • Duramax® torches are designed for high-impact and heat resistance
  • Low maintenance for maximum uptime
Includes:180° machine torch, 25 ft Leads, Starter Consumables Kit
Hypertherm Part Number: 087164
Specifications
Capacity: Recommended Thickness: 1 in. (25 mm) Cut Speed: 20 ipm (500 mm/min)
Capacity: Recommended Thickness: 1.25 in. (32 mm) Cut Speed: 10 ipm (250 mm/min)
Capacity: Severance (Hand Cutting) Thickness: 1.5 in. (38 mm) Cut Speed: 5 ipm (125 mm/min)
Capacity: Pierce* Thickness: 0.75 in (20 mm) Cut Speed: 5 ipm (125 mm/min)
Capacity: Typical Gouge Metal Removal Rate (Gouging): 19.5 lbs/hr (8,8 kg/hr) Groove Profile: 0.23 in. D x 0.28 in. W
*Pierce rating for handheld use or with automatic torch height control
Gas Supply:
Clean, dry, oil-free air or nitrogen
Support
Learn More
