QualiChem XTREME CUT 251C
$44.95
10 lbs.
QualiChem Xtreme Cut 251C is a premium semi-synthetic coolant that prevents rust and is recommended for aluminum and stainless-steel applications.
What's In the Box?
- Each bottle contains 1 gal (3.8 L) of coolant concentrate.
Cut and grind all metals with this semi-synthetic coolant that provides excellent corrosion protection for machine tools and parts, and promotes long fluid life in sumps. Especially recommended for aluminum and stainless steel, this premium lubricant:
- Uses state-of-the-art raw materials to prevent odor associated with most soluble oil and semi-synthetic fluids
- Is nonfoaming
- Contains no nitrite, phenols, silicones, or formaldehyde
- Exhibits excellent hard water stability
- Runs clean
- Rejects tramp oil through tight emulsion
Requirements
- Refractometer to maintain dilutions - we recommend PN 31366 Portable Refractometer - Coolant Tester
Specifications
Recommended Grinding Dilution | 3% (33:1) |
Recommended Machining Dilution | 5% (20:1) |
Recommended Sawing Dilution | 10%(10:1) |
Support
Learn More
