Tormach will be closed Thursday, November 26 and Friday, November 27 in celebration of Thanksgiving. We will re-open on Monday, November 30 at 8 a.m. CST.
Quick 220 Voltage Converting Power Supply
$255.00
4.5 lbs.
Only 1 left
The Quick 220 Voltage Converting Power Supply converts out-of-phase 115VAC inputs into a single 230VAC output - compatible with either 20A or 15A receptacles
Quick 220 Voltage Converter converts nominal 115VAC inputs into 230VAC .   Requires 2 out-of-phase 115 VAC circuits*
  • Inputs: NEMA 5-20 input plugs; includes NEMA 5-15 plug adapters
  • Outputs: NEMA 6-20 (2 Outputs)
  • 20A capacity with momentary over range for starting motors, etc.
  • Maximum Power Rating:4800 Watts at 240VAC
  • 3 hour Duty Cycle at 20A (80% Amperage rating over 3 hours)
  • Footprint: 6.5" x 5" x 3"
  • Includes GFCI outlet tester
Support
Learn More
