RAPID LINEAR MOTION (G00)
  • X~ is theX-axis coordinate
  • Y~ is the Y-axis coordinate
  • Z~ is the Z-axis coordinate
  • A~ is the A-axis coordinate
This produces coordinated linear motion to the destination point at the current traverse rate (or slower, if the mill won’t go that fast). It’s expected that cutting won’t take place when a G00 command is executing. The G00 is optional if the current motion mode is G00.
CONDITIONS
The motion differs if:
TROUBLESHOOTING
It’s an error if:
  • All axis words are omitted -The axis words are optional, except that at least one must be used.
