RH Turning and Facing Holder, 1/2 in. Center for 1/2 in. Square Tool
$280.00
0.9 lbs.
Only 5 left
1/2 IN, RH Turning and Facing Holder for 15L lathe
Turn and face with the same cutting tool and cut down on tool changes. Includes clamp for direct to riser block table mount.
- Solid positive lock minimizes chatter and harmonics
- Accepts 80 deg diamond inserts
- Right-handed cutting
- For use with PN 33326, Riser for 1/2 in. Center Gang Blocks
