SELECT WORK OFFSET COORDINATE SYSTEM (G54 TO G59.3)
To select a work offset coordinate system, program: G54, G55, …, as follows:
  • To select Coordinate System 1, program: G54
  • To select Coordinate System 2, program: G55
  • To select Coordinate System 3, program: G56
  • To select Coordinate System 4, program: G57
  • To select Coordinate System 5, program: G58
  • To select Coordinate System 6, program: G59
  • To select Coordinate System 7, program: G59.1
  • To select Coordinate System 8, program: G59.2
  • To select Coordinate System 9, program: G59.3
TROUBLESHOOTING
It’s an error if:
