SET BLENDED PATH CONTROL MODE (G64)
  • P~ is, if present, the maximum acceptable tool path deviation to round corners to maintain speed – If P is omitted then the speed is maintained however far from the programmed path the tool cuts.
  • Q~ is, if present, the maximum deviation from collinearity that will collapse a series of linear G01 moves at the same feed rate into a single linear move
It’s okay to program for the mode that is already active.
