SET COORDINATE SYSTEM (G10 L20)
  • X~ is the X-axis coordinate
  • Y~ is the Y-axis coordinate
  • Z~ is the Z-axis coordinate
  • A~ is the A-axis coordinate
TROUBLESHOOTING
It’s an error if:
  • An axis other than X or Z is programmed
