SET OUTPUT STATE (M64 AND M65)
NOTE: These commands are only useful when the mill is equipped with the USB M-Code I/O Interface Kit.
EXAMPLE
EXAMPLE
The following is legal:
  • M64 P0
  • M64 P2
  • M64 P3
The following is not legal:
  • M64 P023
  • M64 P0 P2 P3
