Step-Up/Step-Down Transformer
$189.50
19 lbs.
Only 3 left
The Step-Up/Step-Down Transformer may be required for international customers, depending upon available supply power
Changes 220/240 Volt (Foreign Electricity) to 110/120 Volt
(U.S. Electricity). Also can change 110/120 Volt (U.S. Electricity
to 220/240 Volt (Foreign Electricity).
This transformer is primarily of interest to those who want to use a PCNC 770 in areas outside of the USA or Canada where 110/120 VAC is not available. We generally recommend customers to purchase a voltage converting transformer locally instead of purchasing this generic model in order to ensure that your voltage converter will meet local electrical codes and regulations.
  • Fuse Protection with replaceable fuse (Comes with two extra fuses!!!)
  • Front easy access on/off switch
  • All models operate in dual voltage mode
  • Input jack for American Plug
  • Input jack for European Plug also
  • AC Shock Proof sockets
  • Rear 110 or 220 volt input voltage selector for world wide use
  • Front power on indicator
  • Convert power from 110 to 220 volts or 220 to 110 volts
  • European Standard cord built in
  • Free European to American Plug included
  • Many Plug Adapters Available
  • Durable stainless steel chassis
  • Durable industrial type cord
  • Ventilated design for continuous use
  • Led Red Lamp Indicating power sources
  • Dimension: 8" x 9" x 12"
