STRAIGHT PROBE (G38.X)
Conventionally, the probe is tool #99. The rotational axis words are allowed, but it’s better to omit them. If rotational axis words are used, the numbers must be the same as the current position numbers so that the rotational axes do not move. The tool in the spindle must be a probe.
In response to this command, the mill moves the controlled point (which should be at the end of the probe tip) in a straight line at the current feed rate toward the programmed point; if the probe trips, then the probe decelerates.
TROUBLESHOOTING
It’s an error if:
  • No X-, Y- or Z-axis word is used – The linear axis words are optional, except that at least one of them must be used.
  • Feed rate is zero
