1100M Tech Specs
- X-Axis: 18 in. (457 mm)
- Y-Axis: 11 in. (279 mm)
- Z-Axis: 16.25 in. (413 mm)
- Spindle Power: 2 hp (1.49 kW)
- Maximum Speed: 7500 RPM
- Transmission: Poly-V Belt
- Spindle Taper: R8
- Thread Machining: Tension/Compression Auto Reversing Thread Mill
Maximum Feed Rate
- X- and Y-Axis: 110 IPM (2.79 m/min)
- Z-Axis: 90 IPM (2.29 m/min)
- Primary Power Required: Single-Phase 230 Vac, 50/60Hz, 20A breaker
- Table Size: 34 in. × 9.5 in. (863 mm x 241 mm)
- Table Slots: 5/8 in. - Three slots (15.9 mm - Three slots)
- Spindle Nose to Table Max. Clearance: 17 in. (432 mm)
- Spindle Centerline to Machine Column: 11 in. (279 mm)
- Typical System Footprint: 69 in. × 56.5 in. (1753 mm x 1435 mm)
- Overall System Height: 96 in. (2438 mm)
- Typical System Weight: 1600 lb (726 kg)
- Maximum Weight on Table: 500 lbs. (227 kg)
Frame
- Frame and Table: Cast iron frame and table, with hand-scraped hydrodynamic ways and tapered adjustment gibs
- Way Surfaces: Low-friction PTFE-filled, Acetyl-bonded sliding surface. Similar to Rulon® and Turcite®.
- 1 Year Warranty against defects in material and workmanship. Extended Warranty available.
Accessories
- Automatic Tool Changer
- Power Drawbar
- 4th Axis
- Smart Cool™ Coolant System
- RapidTurn™ Chucker Lathe Accessory
- Full Enclosure
- High-Speed Spindle
Controller
