PCNC 440 Technical Specifications
- X-Axis: 10" (254 mm)
- Y-Axis: 6.25" (158.75 mm)
- Z-Axis: 10" (254 mm)
- Spindle Power: 0.75 hp (0.56 kW)
- Maximum Speed: 10,000 RPM
- Transmission: Poly-V Belt
- Spindle Taper: R8
- Thread Machining: Thread Mill
Iron
- Frame and Table: Cast iron frame and table, with hand scraped hydrodynamic ways and tapered adjustment gibs
- Way Surfaces: Low friction PTFE-filled acetyl bonded sliding surface. Similar to Rulon® and Turcite®
Maximum Feed Rate
- X- and Y-Axis: 135 IPM (3.43 m/min)
- Z-Axis: 110 IPM (2.79 m/min)
- Power Required: Single-Phase, 115 Vac 50/60 Hz, 15A Breaker
- Table Size: 18" × 6.30" (457 mm x 160 mm)
- Table Slots: 3/8" - Three slots (9.5 mm - Three slots)
- Spindle Nose to Table Max. Clearance: 11" (279 mm)
- Spindle Centerline to Machine Column: 6.5" (165 mm)
- Typical System Footprint: 42" × 36" (1067 mm x 914 mm)
- Overall System Height: 72" (1829 mm)
- Typical System Weight: 600 lb (272 kg)
- Maximum Weight on Table: 150 lb (68 kg)
- Warranty: 1 Year Warranty against defects in material and workmanship. Extended Warranty available.
Frame
- Frame and Table: Cast iron frame and table, with hand-scraped hydrodynamic ways and tapered adjustment gibs
- Way Surfaces: Low-friction PTFE-filled, Acetyl-bonded sliding surface. Similar to Rulon® and Turcite®.
Accessories
- Automatic Tool Changer
- Power Drawbar
- 4th Axis (COMING SOON!)
- Smart Cool™ Coolant System
- Full Enclosure
- Flood Coolant
Controller
View the Mill Comparison Table
