The store will not work correctly in the case when cookies are disabled.
JavaScript seems to be disabled in your browser.
For the best experience on our site, be sure to turn on Javascript in your browser.
SUPPORTED G-CODES REFERENCE
G00 : Rapid positioning
G01 : Linear interpolation
G02 : Clockwise circular interpolation
G03 : Counter-clockwise circular interpolation
G04 : Dwell
G07 , G08 : Diameter / radius mode
NOTE : The Tormach 15L and Rapid Turn both use G7 (X positions displayed in diameter values). G8 is not used or supported in PathPilot.
G10 L1 : Set tool table entry
G10 L10 : Set tool table – calculated – workpiece
G10 L11: Set tool table – calculated – fixture
G10 L2 : Set work offset origin
G10 L20 : Set work offset origin – calculated
G17, G18, G19 : Plane selection
G20/G21 : Inch / millimeter unit
G28 : Return home
G28.1 : Reference axes
G30 : Return home
G33 : Spindle sync. motion (like threading)
G33.1 : Rigid tapping
G40 : Cancel cutter radius compensation
G41/G42 : Start cutter radius compensation left / right
G41.1 , G42.1 : Dynamic Cutter Compensation
G43 : Apply tool length offset
G49 : Cancel tool length offset
G53 : Move in absolute machine coordinate system
G54 : Use fixture offset 1
G55 : Use fixture offset 2
G56-G58 : Use fixture offset 3, 4, 5
G59 : Use fixture offset 6 / use general fixture number
G61/G61.1 : Path control mode
G64 : Path control with optional tolerance
G73 : Canned cycle – peck drilling
G76 : Multi-pass threading cycle
G80 : Cancel motion mode (including canned cycles)
G81 : Canned cycle – drilling
G82 : Canned cycle – drilling with dwell
G83 : Canned cycle – peck drilling
G85 : Canned cycle – boring, no dwell, feed out
G86 : Canned cycle – boring, spindle stop, rapid out
G88 : Canned cycle – boring, spindle stop, manual out
G89 : Canned cycle – boring, dwell, feed out
G90 , G90.1 : Absolute distance mode
G91 ,G91.1 : Incremental distance mode
G92 : Offset coordinates and set parameters
G92.x : Cancel G92 , etc.
G93 , G94 , G95 : Feed modes
G96 , G97 : CSS , RPM modes
G98 : Initial level return / R-point level after canned cycles
