SUPPORTED M-CODES REFERENCE
- M00: Program stop
- M01: Optional program stop
- M02: Program end
- M03/M04: Rotate spindle clockwise/counterclockwise
- M05: Stop spindle rotation
- M07/M08: Coolant on
- M09: All coolant off
- M10/M11: Unclamp/clamp automatic collet closer
- M30: Program end and rewind
- M48: Enable speed and feed override
- M49: Disable speed and feed override
- M64: Activate output relays
- M65: Deactivate output relays
- M66: Wait on an input
NOTE: M64 through M66 is only useful with a USB M-Code I/O Interface Kit (PN 32616).
- M98: Call subroutine
- M99: Return from subroutine/repeat
- Introduction
- Programming Overview
- Programming G-Code
- Rapid Linear Motion (G00)
- Dwell (G04)
- Set Offsets (G10)
- Length Units (G20 and G21)
- Straight Probe (G38.x)
- Absolute Coordinates (G53)
- Distance Mode (G90 and G91)
- Programming Canned Cycles
- Programming M-Code
- Supported M-Codes Reference
- Tool Change (M06)
- Feed Override Control (M50)
- Wait on Input (M66)
- Programming Input Codes
- Advanced Programming
