TalonGrip / VersaGrip Vice Jaws - Mitee-Bite PN 33006 - Not Compatible with Tormach 5" vise
$419.00
20 lbs.
NOT COMPATIBLE WITH TORMACH 5" VISES
STEEL VISE JAW SET
Part Number Vise (metric) A (metric) B (metric) C (metric) D (metric) E (metric)
32066 4″/6″ (100mm/150mm) 6.0 (150) 1.73 (43.94) 1.0 (25.4) 2.5/3.88 (63.5/98.55) .688/.94 (17.47/23.87)
This system can accommodate a wide range of part sizes as well as holding multiple parts in a single cycle. The hardened (51-53 RC) VersaGrip™ has penetrating teeth designed to bite into your workpiece preventing lateral and horizontal movement. These grips will hold flame cut parts, castings, even parts with a negative draft!
STEEL VISE JAW SET (Set includes 4 VersaGrips™ with M5 Screws)
Part No. Vise (metric) A (metric) B (metric) C (metric) D (metric) E (metric)
WITH MOUNTING HOLES
32166 4”/6” (100mm/150mm) 6.00 (150) 1.88 (47.75) 1.0 (25.4) 2.5/3.88 (63.5/98.55) .688/.94 (17.47/23.87)
