TEMPORARY WORK OFFSETS (G92, G92.1, G92.2, AND G92.3)
IMPORTANT! This is a legacy feature. Most modern programming methods don’t use temporary work offsets.
  • X~ is the X-axis coordinate
  • Y~ is the Y-axis coordinate
  • Z~ is the Z-axis coordinate
  • A~ is the A-axis coordinate
G92 reassigns the current controlled point to the coordinates specified by the axis words (X~, Y~, Z~, and/or A~). No motion takes place.
EXAMPLE – If the current controlled point is at X = 4, and there is currently no G92 offset active, and then G92 X7 is programmed, this reassigns the current controlled point to X = 7 — effectively moving the origin of the active coordinate system -3 units in X. The origins of all inactive coordinate systems also move -3 units in X. This -3 is saved in parameter 5211.
It’s an error if:
  • All axis words are omitted
To reset axis offsets to zero and sets parameters 5211 – 5219 to zero, program: G92.1
