Through Spindle Coolant Kit, 1500MX
$6,995.00
400 lbs.
1500MX Through Spindle Coolant Kit
What’s in the box:
- Through Spindle Coolant Pump
- Fittings
- Filter with brackets and wrench
- Pickup sump
- Pickup hose
- High-pressure output hose
- Rotary union
- Overpressure return line
Through spindle coolant (TSC) is a method of cutting and lubricating cutting tools during machining operations. It is essential in deep drilling operations to keep your tools clear of chips and the bore flushed clean. Our user-installable TSC kit for your existing 1500MX gets the coolant right where you need it to help break and flush chips out of drilled and milled features.
The kit comes with everything you need to add TSC to your machine.
Requires flood coolant kit, PN 51567.
Note: Only compatible with 1500MX Mill
Specifications
- 3 HP, 220V single phase motor at 20A (12.5A draw)
- 435 PSI (30 BAR) max outlet pressure
- 7.9 GPM (20 L/Min) max flow rate full open
