TNMG 222 Insert 10-Pack
$114.95
0.01 lbs.
Only 3 left
The TNMG 222 Insert is a negative insert with chipbreaker recommended for semi-finishing and finishing of Steel
Package of 10 Lathe Inserts
  • ISO Code/Manu. Code: TNMG 110308-DM
  • ANSI Code: TNMG 222-DM
  • Type: Cemented Carbide
  • Grade: YBC252
  • Comparable ISO Grade: P10-P40
  • Surface Prep: CVD coated Al2O3/TiAlN composite coating
  • Cross Reference: ZCCCT, Sandvik, Kennametal
  • Shape: Triangle (T)
  • Clearance Angle: 0 (N)
  • Tolerance: Class M (M)
  • Type: Double Sided (G)
  • Insert I.C.: .250" (2)
  • Thickness: .125 (2)
  • Corner Radius: .031 (2)
Notes: For semi-finishing and finishing of Steel
