TOOL CHANGE (M06)
M06 behaves differently depending on whether or not a mill is equipped with an Automatic Tool Changer (ATC):
  • If you have an ATC:
    • If the tool is not assigned to the carousel, you’re prompted to manually change the tool and select Cycle Start to confirm the tool change. This resumes the program.
  • If you don’t have an ATC:
    • M06 commands the mill, stops the spindle, pauses program execution, and prompts operator to change tools by flashing Tool Change LED.
EXAMPLE – N191 M06 T3 G43 H3
