Toroidal Cutter - 16 mm
$100.50
0.25 lbs.
Only 2 left
The Toroidal Cutter - 16 mm (0.63 in.) is a 2 flute indexable round insert mill ideal for both facing and for pocketing, where it can be used to make inside corner fillets
16 mm (0.63 in.) 2 Flute Indexable Round Insert Mill. Ideal for both facing and for pocketing, where it can be used to make inside corner fillets.
- 2 Flute Indexable Mill
- 16 mm (0.63 in.) Cutting Diameter
- 23 mm (0.91 in.) Height
- M8 Screw Stud
- Hardened Tool Steel Body
- Precision Machined Insert Pockets
- Use With T9 Insert Tool
Inserts Sold Separately.
Includes Insert Screws and Wrench.
