Touch Screen Kit
$459.95
17 lbs.
The Touch Screen Kit allows you to Conveniently operate PathPilot through a LCD resistive touch screen.
What's In the Box?
In addition to the monitor, the kit includes:
- Assorted mounting hardware
- Cables:
- 10 ft (3 m) power supply
- 10 ft (3 m) USB extension
- 15 ft (4.5 m) SVGA
- Desktop stand
- Installation instructions
- VESA mounting plate for optional Machine Arm (not included)
Even when you’re wearing gloves, you can conveniently operate PathPilot through this LCD resistive touch screen. Once you’ve mounted this touch screen on any flat cart or directly on the optional Machine Arm (not included), with the touch of the finger, you can easily:
- Start, pause, and stop programs
- Change feeds and speeds
- Create conversational programs
*Some assembly required.
- Machine Arm (optional; not included)
Requirements
- PathPilot controller with HDMI port
Specifications
Display Resolution | 1280 x 1040P |
Size | 17 in. (430 mm) |
Connectivity | DVI and HDMI |
Resistive Technology | Analog 5-wire |
