TTS Collar: 3/4 in.
The TTS Collar: 3/4 in. is a TTS Tool Conversion Kit (Light Press Fit) - compatible with Tormach ATC
Kit can be used to convert many conventional tools with 3/4 in. shank into Tormach Tooling System tools.
- Light Press Fit on .750 in. shaft (.748 in. +0/-.001 in. collar ID). No adhesive required, install with an arbor press (not included)
- Steel Ring with Black Oxide Finish
- Groove Geometry is compatible with Tormach ATC
Learn More
