TTS™ Metric Tool Holder Set
$1,295.95
30 lbs.
The TTS™ Metric Tool Holder Set offers everything you need to need to get started and more with our Tormach Tooling System (TTS™) tool holders.
What's In the Box?
In addition to the Tormach Tool Assistant Set and TTS™ Tool Tray, the set includes:
- Anti-seize grease
- TTS™ ER Collet Holder: ER20 (six)
- ER20 collets:
- 3 mm (two)
- 6 mm (two)
- 10 mm (two)
- ER20 Deluxe TTS Wrench Set
- TTS™ set screw holders:
- 10 mm (two)
- 12 mm (two)
- Jacobs Drill Chuck-1/4-inch-JT1
- Jacobs Drill Chuck-3/8-inch-JT2 (two)
- TTS™ Drill Chuck Arbor: JT1 taper
- TTS™ Drill Chuck Arbor: JT2 taper (two)
The TTS™ Metric Tool Holder Set provides everything you need to get started with our Tormach Tooling System (TTS™) and expanded tool holding options, and includes the Tormach Tool Assistant Set and TTS™ Tool Tray.
Features:
- Tool holders:
- ER20 collet holders
- Set screw holders
- Jacobs chucks for drills
- Tormach Tool Assistant Set:
- Compact, granite surface plate
- Integrated clearance hole
- 200 mm digital height gauge
- USB interface cable with touch trigger for PathPilot integration
- TTS™ Tool Tray:
- Varnished wood
- Storage for 21 TTS™ tools
- 1100M
- 770M
- PCNC 1100
- PCNC 770
- PCNC 440
