Vacuum Sponge Cup Gripper
$419.00
7.4 lbs.
Only 2 left
Sponge vacuum cup with integrated Venturi vacuum generator for ZA6 robot
What’s in the box?
- Sponge vacuum cup with integrated Venturi vacuum generator
- Aluminum adaptor plate to mount to mount gripper to ZA6 tool flange
- Qty 4 5mm socket head cap screws
Sponge vacuum cup with integrated Venturi vacuum generator for ZA6 robot. Takes regular shop air as an input and uses the integrated Venturi to create a vacuum to grasp objects like metal, plastic, wood, cardboard. Suction varies with material surface and porosity. Recommend PN 51776 Solenoid Kit to control air flow to this gripper.
Specifications
- Dimensions: 3.14 x 3.14 in. (80 x 80 mm)
- Air volume: 30L/min
- Pressure: 0.4-0.6MPa
- Suction: 12N(Vacuum degree-60KPa)
